Well on my way home from work my power-steering pump pulley wheel decided it didnt want to be attached to the pump anymore and it has sheared the spindle bit in the inside
. Have had a dry bearing for a while so I think the bearing has siezed.
I have another pump already (thanks athers
) so that is all sorted.
The pulley came off roughly 5 miles from home, so I managed to nurse the car home. But the belt went with the wheel and well the belt drives the water pump and alternator aswell. So I had to drive 5 miles with no water pump and very heavy steering.
But in the 5 miles the temp gauge never moved from the middle, will there be any engine damage that could of occured or should everything be fine?
. Have had a dry bearing for a while so I think the bearing has siezed.I have another pump already (thanks athers
. I wonder if it is,
