Fook it, just ordered some denso irdium ik22's haha
Goddam, ordered Forge cold-side relocation, actually cant help myself lol
Gonna go see if my itg filter is in at motoscope now and order some plugs i think
This pic shows that both pipes are exactly the same length though, its just the angle you're holding it at and the curve of the pipe thats causing somewhat of an illusion. If you look at the edges of the blue and black pipes at the bottom end, they are in line with each other. Keep trying to fit it, you'll get there eventually... the pipes are always a tight fit when they're new.
Best way to measure it is with a piese of string!!!
If its too short then I'm sure Forge will sort it out, Scott..
its not an illusion, look back up at the top of the pipes, they are inline and not offset like the bottom ones. I get what your saying but look at it again, your getting confused with the picture. Thats why i did a few angles
No need to measure to tell its miles shorter in this case though, not a chance in hell![]()
