Red seat belts or sparco harness?
Mk2Ibiza
232
Middlesex
I like the look of racing harnesses however the beeza isnt exactly a race car, however i was on vagcat and saw they sell red seat belts, any one have any pics they can share?
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
If you search tiger stripe interior, it will show the red seatbelts, as they came with them from factory
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
as suj said!
unless your considering striping it properly (look at dinky dave or f2stus threads!)
Gav_F
187
i want red belts :( had my red sparco harnesses in it when it was stripped for santa pod but it was a pain in the arse! lol
Mk2Ibiza
232
Middlesex
Thanks for the replies guys. Would it be better getting them from the main dealer or searching the net. Tried ebay but nothing.
Also how easy are they to fit?
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
You also shouldn't put harnesses on seats not designed for them (i.e. standard folding back seats). Harnesses run through the seat above your shoulders and in order for them to work the seat has to retain structural integrity should you crash. With folding back seats there is a risk in a crash that the belts will cause the back of the seat to collapse, destroying your back in the process.
ather`s
EXEO Sport & mk2 IBIZA
Sep 7, 2008
2,059
mansfield, notts
to get a full set from the dealers, you are looking at £600+!!!! the reason i know is because a while ago i looked into this. luckily, ibought dinky dave`s interior which had a full set of belts too. also i found 2 more sets on ebay, bought them, kept 1 set and sold the other.
they are easy to fit as long as you know how to use a spanner??
Aug 22, 2008
3,221
cannock
check ebay there always popping up on there
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
I managed to get a set of red belts from someone breaking there car on here for about £40 I think I paid.
Easy to do, just need a screwdriver and a ratchet with a 17mm socket I think it was. Only thing thats a pain is removing the trim and then getting it back on properly after lol
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
gav, harnesses on standard seats = serious back injuries in an accident, as they are not designed for them, they will break the seat, and your back in the process :(
Mk2Ibiza
232
Middlesex
:cry: looks like im gonna have to get some buckets but i think they look odd in a car that will most likely never see a track.
Im only after the belts, im going to check on the for sale section, what bits would i need if i were to get em off the dealer? ie, any mechanisms? or anything else.
Im fairly handy with a spanner, took my pedal box out :clap:
They are very nice!! Im definately going to have to source these :idea:
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
where the old belts were secured
Not quite. You might be able to get away with re-using the point on the pillar side of the car, but you will have to drill into the transmission tunnel on the other side to fit a mounting point. This is because the clip for the standard seatbelt is attached to the seat itself, so if you replace the seat you lose that mounting point.
