In case any other CR TDI Leon owners are thinking their mpg figures aren't as good as they should be, I've recently had a bit of a revelation... turns out I've been driving my Ecomotive far too gently.
My (admittedly basic) understanding of cars and mpg made me think that the gentler the braking/acceleration inputs, the better the mpg. But since the cold weather, I've been seeing worse figures than previously: about 58mpg tank average. It didn't improve much when the temperatures increased either.
So, after reading some tips on a hypermiling forum, over the last few days I've recently been using much more throttle to get up to speed: instead of accelerating as slowly as I could bear to and changing up as soon as recommended by the indicator, I've been using much more throttle (not flooring it, but very brisk acceleration) through the first few gears, then easing off as soon as I reach my desired cruising speed.
Because the low gears are inherently inefficient, it turns out that using more right foot to power through them quicker (and using more revs/boost in the process) is much more efficient than creeping the speed upwards and changing up asap to avoid using boost.
I've also increased my target speed/revs from about 52/~1,200 to about 62/~1,700. Driving *faster* by 10 mph in this way has actually improved my mpg too. Weird but true!
Seems counter-intuitive, but I'm certainly not complaining - just wanted to share this in case I'm not the only one who's been getting this wrong. Apparently it's something to do with the engine being more efficient between 1,500-2,000 revs than it is between 1,000-1,500 revs.
Once at cruising speed, I'm still using my tried and trusted techniques to maximise economy: trying to 'drive with load', avoiding cruise control, trying to anticipate ahead and avoid unnecessary acceleration/braking, etc.
I've been consistently seeing >65mpg journey average for my 40 mile commute since I started putting my foot down a bit more...
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Think about it..
