Pela oil Pumps
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
Anyone used one of these on the 2.0TFSI?
Are these what the dealers use?
I'm thinking it would be good for intermediate oil changes. Saves changing the filter and dropping the under tray. I only do about 8k a year so changing the filter isn't really needed between services.
Luap
I use one on my 1.9Tdi Ibiza Cupra... Brilliant! Make sure the engine is reasonably warm though... First time I used it, it took about 2 hours to suck the cold oil out! Oops!
Now I can do an oil (and filter change) in half the time, plus I can suck it all out of the oil heat exchanger too, which I had to previously disconnect underneath!
If you are only doing an intermediate - without the filter change - you won't even need to wash your hands afterwards!
HTH,
Luap :eek:)
Nov 2, 2004
9,335
South Wales
I got one of these, Pela 6000 and ive used it on a number of cars. Even took the sump off after using it on my ibiza and it was pretty much empty, far more out than a normal drain.
Well worth it, just make sure as said above you warm the oil up. Which means just going for a blast. :)
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
Ordered the pump today. Hope it works ok with my engine.
Nice clean way of doing the intermediate changes by the look of the videos I've found of it.
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
Tried this today and only got 3ltrs of oil out. :confused: The car was parked facing down a slight incline, that usually gives a higher reading on the dip stick so assumed it would get more out.
I read on another forum that a guy had this and tried his facing uphill and got more out, but this was on a TDI.
The oil had only done about 3k so I just kept it out and put fresh stuff in. Means I have plenty left for top ups.
Anyone had this issue?
Cupra R
2,217
UK.
Visit site
Yes mate, I had the exact same issue. Resorted to the good old fashioned way of getting under the car in the end.
My car was on level ground at the time.
Let us know if you have anymore joy pointing uphill.
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
What engine was it on? I measured the dipstick and marked the pipe for the pump to make sure it was into the engine enough. It even went down about and inch more. I could feel it hitting something that I assumes was the bottom.
I even dipped the oil after I pumped it out........and the dipstick was clear!!?!??!?
Cupra R
2,217
UK.
Visit site
2.0TFSI
I too hit a rock solid bottom and thought I was into the bottom of the sump, but obviously not.
I wonder if the sump is baffled maybe and the suction tube hits it, not allowing full drainage:confused:
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
Yeah, but the dipstick was dry after pumping out all the oil I could.
Unless it doesn't actually register on the bottom of the dipstick till there's a litre of oil in there.
Cupra R
2,217
UK.
Visit site
Not sure, unless the small size of the Dipstick goes through something in the sump :confused:
Someone who has had these engines in bits maybe able to shed some light maybe.
Although after shelling out for an Oil Filter Drainage Tool, I'll probably just carry on now the old fashioned way :lol: Filters aren't expensive from Sere
Cupra R
2,217
UK.
Visit site
Oh well. I'll be doing the proper service changes using this guide - http://www.golfmkv.net/blog/archives/8#
Thats a very good guide.
With regard to the pump, mine used to work perfectly on my Mk 1 LCR, so it must just be something in the TFSI's Sump or something.
Anyhow, for the cost of a filter I think your better off changing that too modified or not, it doesn't hurt to keep on top of things.
Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
I read that it might have a horizontal baffled sump. It doesn't explain how the dipstick gets its reading though. It must be sitting off the bottom off the sump.
Cupra R
2,217
UK.
Visit site
Without knowing for sure then I can only assume the Dipstick goes through a small hole into the sump.
What size pipe did the Pela come with?
Mines a Sealey and the smallest pipe has an OD of about 6mm
