LCR Spark Plugs???
johno1404
4 DOORS FOR MORE *****S
Aug 22, 2005
278
Hertfordshire
Sorry lads i thought i would pick your brains on this one
I have a 2004 LCR (225). I have only owned it since September last year and recently done a service on it.
The spark plugs i removed were Bosch Super Plus FR7LDC+ (twin prong)
and the ones i recieved from Sam Centre were Bosch Super Plus FR7KPP33+ (single prong)
the reason i am asking if the new ones i was sent are the correct ones for my car as i checked the part number of the set i removed and they match up to a 1.6 Golf or Beetle engine
Just wondered if anyone had a park number or description of the ones they are using???
Feb 22, 2006
516
Penzance Cornwall
personally after the experience i just had with bosh plugs, the best place for them is the in, i cant imagine that the ones they have sent you would be correct either. Try and get some NGK plugs instead.
Feb 26, 2009
5,275
Wolverhampton
They are likely to be the same ones, if I remember correctly the plugs for my V5 Toledo are the same that are fitted to the 1.2 Polo!
I have to admit I do go for NGK though, I can't really criticise Bosch but I've always managed to get NGK cheaper.
lloydie
66
slough
im not allowed to post URLs to other sites after i have made 15 posts or more.
but search them on ebay
found these, dont have a part number but are the same, i was advised on average every 50bhp over standerd bhp go a grade cooler in spark. so also might depend on your bhp to what spark plug you need =)
phatchoonz1
89
Orpington, Kent
If its remapped and running harder than standard, I'd recommend BKR7EIX (2667) in NGKs - they're the iridium's.
If it's still on a standard ECU map, I'd go for the standard NGK option of PFR6Q (6458) which are platinum plugs.
lloydie
66
slough
arent they heat grade 7 as standerd? and what bhp would you suggest you would need to be running to go to heat 8? =)
sambryant
RoadRunner meep meep
Mar 26, 2009
4,845
Bristol
I thought the more power you were running the higher the grade? eg 200bhp can run a 6 and a 260bhp run a 7 etc... a higher number deals with heat better so keeps things cooler.
wrong, i took my advise from bill at badger 5.
What are the drawbacks of using a lower grade plug on a higher bhp car? I'm just interested to know.
theres no downside m8, car will fire up quicker, plugs will last longer as they run cooler.
phatchoonz1
89
Orpington, Kent
Sorry Sam, Knightrider is correct. The higher the number the cooler the grade of plug.
See here for the NGK tech info on heat ranges:
http://www.ngksparkplugs.com/tech_support/spark_plugs/index.asp?mode=nml
As I said above 6 is standard for the LCR (as in PFR6Q platinums) and 7 is the cooler option for remapped cars running higher boost and increased ignition timing advance and hence higher combustion temperatures (ie. BKR7EIX for the iridium option).
To quote the NGK site
"The heat range must be carefully selected for proper spark plug thermal performance. If the heat range is not optimal, then serious trouble can be the result. The optimal firing end temperature is approximately between 500°C (932°F) and 800°C (1472°F). The two most common causes of spark plug problems are carbon fouling (< 450°C) and overheating (> 800°C). "
sambryant
Mar 26, 2009
4,845
Bristol
Im only going by the advise of one of the greatest vag tuners around. He told me to use 7 as its cooler, im unsure what stock actually is, all i no is 7 is cooler than stock and will run better in my lcr. You can ask badger 5 your self.
sambryant
Mar 26, 2009
4,845
Bristol
I know im not wrong in sayin 7 is the cooler plug, this is the correct plug to run in a mapped lcr.
