It's a concept car... Seat actually wanted to make that. While these photographs were taken, the car was probably still a clay model with grey/silver foil laid over it, just to get impressions. I guess they just did not decide the height of the rear end yet ;)
Still, you know you want it right? :D
That Car was in the modelling stage still, likely that there isn't actually a proper shell under that car. Different height on different sides to try out different body mods as it is cheaper than making the whole car.
Beaten to it by mythbuster.
Seems like the left side is the height of the actual Ibiza(under the windows) and the rear is the height of the Cordoba, or vice versa...
I love it... I want one badly! :( You think they could help me build one? If I give them the puppy eyes?...
Biggest problem will be the strengthening of the chassis/bodyshell/(whateverelse you want) to call it required. Work that out and the rest will follow.
Sure Seat will help me with that right? :(... Roof of the mk3 Golf, rear end parts of a Cordy 2-door... Lights custom made... All set? :D
If I have enough money and I remember this, I will try it :D
Arun: Yes you are. :D
@Below: :(.... I love it!
I luv it.... Maybe if someone would try to make this, they should use the rear lights of the Ibiza instead of custom building hem. I think cutting it up below the window and then use the top of the bootlid of a Cordoba coupé, you could make it a lot better than with these weird lights...
Then again, I hope you take into consideration that the whole front is messed up because it's only a study model...
Edit: Nvm, use a Cordoba Coupé and weld in the Ibiza taillights... Would make it WAY better I bet!
Edit 2: Or maybe you should use an Ibiza... Would make it a lot shorter which could make it nicer?!...
maybe it has got the H4 headlights because he has got HIDs on it..?
Or someone bought angeleyes and a badgeless grill for it and the new owner wanted it back to standard. So bought headlights and grill from a lower spec without knowing the difference.
I've thought all of this ^ ^ too... Might be as innocent as that... or Morette headlights?... but with no service history, and no passenger airbag, I'm not sure. :(
