no dont use normal silicone, i used it and it corroded away. i used it on the inlets to make them bigger as the cans inlets are 15mm and the oil hose is 19mm.
there is a special type of silicone you can use but its very expensive, oil resistant hose is what you want.
I bought the normal silicone from eGay, it was crap, waste of money, just kept kinking, collapsing at the slightest movement with hardly any bend at all.
To offer some comparison, Rich Tea vs Hobknobs..........eGay Silicone vs Oil Resistant!!
i have looked every where for a silicone reducer from 19mm to 15mm and can't find one anywhere but found 19mm to 16mm and i'll just make sure it's really tight and secure on the can.
Yep, thats the problem i had, down to 15mm, bought a 25mm to 16mm, a 16mm pipe joiner and 2m of 16mm, the 2m of 16mm silicone was cack as i said! So my project is on hold at the mo....
