brad1
You shouldnt have to fit a spacer to not get an error code, there is a problem in the new map, i kept getting two codes continually. One being 1810 power supply terminal 30: voltage too low. Only got the code with the new AmD map. It triggered the EML light every time the error came back. Also the next code was 16804- catalyst system bank 1: efficiency below threshold. The both popped up a couple of times while during the two weeks the AmD map was on the car. Also on a few occassions the car would start in limp mode, so you had to turn it off and back on and it was fine. AmD did try to sort this out and it did cure it but a week later it kept happening so i just had revo put back on and didnt ever experience none of these codes or problems again. Your codes are to do with the map Tom
