this is from vwvortex;
i would check your PCV system i had a similar
problem and it was a plugged hose on the PCV system. when the car is idleing the rings are relaxed because your pulling vacuume allowing you to suck oil in if there is a build up of pressure in the block if the PCV line is plugged up.
