im doing a service in the next couple of days and heard you need to change the copper washer on the plug.. is this the case or can i get away with using the old one?
Yep all VAG dealers change the sump plug complete. The washer is part of the plug. Stu il bring a couple home. If your about we can meet up and il give you them.
You can always anneal the exsting washer (provided it isn't split) to soften it for re-use. Heat to cherry red and allow to cool. A new one is better though. While its off, measure it so you can get a new one from Halfords next time
iv seen a magnetic one on awesome with 10 washers for £12 so might just get that.. it gets serviced at garages anyway but i like to do a few oil changes inbetween lol
dealers should realistically stock both the bolt (with washer) and washer seperatley - not all VAG vehicles have the same sump plug so some require a new washer, on the ibiza 1.2s the sump plug and washer are 2 seperate parts but the washer also fits the other models using a 19mm plug.
i used to have 100s if not 1000s in a tub in my box at the dealers from all the services i'd done, i kept them like scalps - dunno why really?
and for the sake of £1 or £2 you might as well change it.
