Sorry to hijack the thread but were does the center part of the rollbar connect to on the rear axel?
You must have removed that shock to get the bolt in place as the head is under the shock on top.
I bent **** out of the brackets after a while and bolted the rose joint straight to the hole show on the end of the arm.
No need for brackets imo.
Hopefully get this fitted at the weekend if i can get a dry place to work, my garage is no longer a garage :L full of junk so its a no go just now! Im hoping the difference the bar makes is as good as ive been told, what setting am i best trying first??
Sorry Bill i dont understand how it can affect anything botling it to the beam. I still have adjustment and rose joints move in any direction more than what is probably required.
Can't see how this ARB will have any effect on a stiff rear axel ? Please enlighten me![]()
From what i remember when i looked (around january!) The centre part joins with the brackets supplied in the kit as it would on the cars its designed for, unless ive picked your question up wrong?
