You just running a iPod tape in your standard stereo at the mo?
You can double wire an fit a cd player under your steering wheel in the little pocket bit or take out the middle vents in your dash an put it there,I've got pics on the computer I'll put them
Up if ya like..or pm me an I can give you the guys number that sorted myn with me!!
back for a cheeky little update ABS killed its self on sunday it uncliped its self an got stuck between my cv boot an rubben my wire!!! shrink tube n solder iron got that back on track!!
yer it worth it just make sure you get a good pipe an use a foam filter as the one i have is shite you get better air forsure i have a cone just of my maf an it alot better than that so i think!
but having the air filter down there its picking plenty of water up , even your air filter is rusty so the water is going to be sucking up the pipe work personally would do away with that set up
whats spacers you runnig then?
also go for a cone filter bud, foam filters are crap. I had a foam pipercross and it kept killing my mafs, havent had a single problem with my jetex
