Just thought I'd poke my head in and explain why the hitachi coils lose power. It's nothing at all to do with reduced voltage, but everything to do with ignition timing. You need to know how ignition coils work for this to make sense. I presume most people on here do, so here goes:
The hitachi coils take longer for the electromagnetic field to break down, compared to the push in type packs. This means it takes longer for the spark voltage to build up, making the the spark happen later in the piston cycle, effectively retarding the ignition timing, and loosing power. The
problem will get worse as the RPM's increase.
That is also why people report noticeably smoother idle when using Hitachi packs, as the ignition is not being advanced as much.
And it's true what you say about the old AGU packs. They are NOT the same as the Hitachi ones. They have 3 wires instead of 4, and are quite often black with the green VW Audi logo written on top of them. They also use a separate ignition amplifier, which is bolted to the airbox lid. The 4 wire packs have the ignition amplifiers built into them, so don't need a separate one. This type hasn't been used in the leon, but was used in the golf, old octavias, and old Audis. There have never been any 180 engines using this setup.
Oh, and techincally it's not an ignitor, its a MOSFET switch.
