I went with a standard replacement clutch and mines been fine. Just dont go racing off the lights every 5mins and you will be ok. You know what power im running!
I'd say Kenny but you cant always talk to him over the phone.
Tom, stick with the stock clutch but ask AMD to reduce peak boost a little to stay under 300 ft/lb and then the clutch should last a long time. Any idea what your peak boost is.
Just to let you know mate eurocarparts have a sachs clutch for £160 but this month they have a 30% off all service car parts clutches seem to be included. just bought 1 for £112! Bargain,
Code - service30
Hope this helps
I still have the stock clutch(52k), it just needs to be treated with a little respect, i have had it running up to 330lb/ft and on dyno it only started to slip during normal power output at 360lb/ft + while test the Hybrid V1.
Avoid power launches and you should get more use out of it.I did slip intially after remapping, i just changed my driving style to suit.I will happily push the stock clutch to 330lb/ft.
I hate my clutch and flywheel set up BUT!!
I wouldn't put an OEM part into such a highly specced car.
It really depends on what you want to do with your car and how you plan to drive it.
I didn't want to be limited by an OEM clutch in how I drove.
If you do then go for it.
The Southbend clutch is supposed to be OEM feel but will be linked to a SMF which does give extra noise.
Mine is a Spec stage 1 good for 320 ft-lbs and a Spec SMF, no slip yet with hard lauches, 300 ft-lbs and R888's
im running the sach clutch with a dmf, its a bit noisy, with the clutch depressed but can launch with wotbox with no problems,
i paid 600 for my clutch when i brought mine as part of a group buy about 10 minths ago
this is what i have
http://en.sachsperformance.com/sach...uq-ary/druckplatte-verstaerke-ausfuehrung.htm
http://en.sachsperformance.com/sach...rsionsgefederte-scheibe-mit-organischen-2.htm
Personally Tom I would go with the race helix set up your more than welcome to come test mine in my car I paid 952 quid for the whole kit there rated to 450 bhp , my mate can fit them for 100 quid
Alcon do a ceramic clutch for the LCR its what they use in the race cars not sure on price tho? http://www.alcon.co.uk/:confused:
i been told its noisy as if look at friction plate its not got dampening springs so is noisy without clutch slightly depressed, also been told its organic yes
how do you do the remote windows?
No worrys drop me a pm my cars going in the body shop soon so it depends how much of a rush your in the clutch is awesome slight chatter but you get used to it
cheers for links mate,
im running the same clutch as your friend i believe, i also run the LUK flwheel and release bearing, as well as the wavetrac diff which i love
allthough my clutch pedal is harder to depress i love the feel of mine and the sound doesnt annoy me to much i will try make a video at the weekend to show you, is not that loud just i no its there
	I love when a quick wash turns into a mini detail!
Great reflection shots mate, car is looking so so good there man, makes me wish I had looked for a Plat one!
Meguires is awesome stuff,I don't bother anything else. Looking good fella,once I get my wheels refurb'd,I'm gonna get it detailed. Love your car,I've got the sake colour,looks brilliant when its clean.
