Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Cheers Guy's i am going to do a compression test this weekend before i do the rebuild so i know which cylinders are at fault, and out of interest tbh.
Oh dear, i have just done my test and ( 1 being nearest the cam belt)1, 75psi 2, 80psi 3, 85psi 4, 85psi so the rebuild is definitely needed.
How many miles have you done Phil? Just curious to see the state of play on your motor. I'll maybe get the old compression tester on mine in a few weeks (just passed 124k miles!)
No not going with the stroker, it worked out to expensive and what with an issue i have had to deal with i cant stretch to it now so getting the head ported polished and flowed and ferrera exhaust valves, new rods and yes IE but 19mm w/p i got them from Dave (DJP) together with coated bearings, i will then fit new rings, i have also asked Sam for a quote on a sm fly wheel and clutch kit but have not had a reply yet?? The head work will give a bit more power but not looking to go any further power wise now its got to the 300 mark, hopefully the rebuild will give a bit more but reliability and a strong engine, this is what i am after, i really want to stop having to use it as a daily and for work, get the respray and use it at weekends and the odd event.
Exactly the same as you 124000![]()
