Crezzlin
45
Any advice guys, low compression on all 4 cylinders, around 60-75psi on all, car has 106k on her and starts fine but have had some random misfires that come and go. Was going to change belt and chain this week but thought I'd check compression first ? Thanks
Thanks, everyone. I bought a second compression tester, ran the engine dry, removed the spark plugs, and tested all cylinders—same results as before. After removing the Schrader valve, I’m now getting 120 PSI across all four cylinders. I also replaced the spark plugs, and the misfires are gone. The engine starts up easily every time, there’s no smoke, and it's drawing proper vacuum from the oil filler cap.
Next up: I’ll be replacing the timing belt and chain this week and performing a B-12 cylinder flush. Fingers crossed! ?
