Current Spec
Engine
K03s Turbo
Jabba sport Custom Map
Full engine rebuild with Scat rods and uprated race bearings. Head fully rebuilt and cleaned.
Custom powerflow Downpipe with 200 cell sports cat (about to add V-band clamps so i can just fit a 400 cell cat for MOT and run everyday with de-cat)
Powertec filter (Ram-Air filter soon to be fitted)
Blue Forge TIP (Want red)
Forge 007p with yellow spring
Forge FMIC all blue hosing (All soon to be replaced by new toyo sports large FMIC with black alloy pipes and Red Silicone from Auto silicone hoses)
N249, N112 Bypass
carbon canister delete
SAI delete, forge blanking plate.
Aircon removed
Black silicone Vacuum Piping
Rocker cover Sprayed red
Inlet mani satin black
Tranmission
8N0 711 046 TT short shift
ECS stage 2 clucth kit rated to 330 WHP and 380LB/FT.
ECS Tuning 14LB flywhhel
Chassis
Neuspeed 25mm Front ARB
Neuspeed 28mm Rear ARB
H&R shocks with 30mm springs on rear and I believe it is 40 or 50 on the front.
PowerFlex Front Wishbones
Seat Sport MOMO front upper strut brace (red)
OMP front lower strut brace (red)
OMP rear upper Strut brace (anthracite)
Brakes
Cupra R Brembos 305mm disc (Red)
Brembo discs and pads on the rear. rear calipers red also.
Wheels
16" black Team Dynamic Pro race 1.2s alloys with red lip
Exterior
LCR Front Splitter
Debadged
Rear Wiper Removed
carbon insert Stubby Ariel
Carbon wrapped Seat Badges
Rear arches slightly rolled and surface rust removed and arches re painted.
Interior
Nomad Double Gauge Pillar Pod
Cupra R Gauge Holder
Glowshift boost and oil pressure gauges
OEM oil temp and volt gauges
Next on the list
Toyosports FMIC and custom pipe work (bought just needs fitting)
set of OEM stylebutterfly bucket seats out of newer VAG car
Full Respray
Bump strips colour coded
Engine
K03s Turbo
N249, N112 Bypass
Aircon removed
Tranmission
Chassis
Brakes
Wheels
Exterior
LCR Front Splitter
Debadged
Rear Wiper Removed
Interior
Next on the list
Full Respray
