Gavbey's stage 2 mk3, FIXED
gavbey
THE SPARKIE
Oct 7, 2009
323
Perth / Lerwick
long time no see mr progress page.
not much to add apart from bout a new lambda sensor......
we will see how here running isuels are once its done.
also would andone care to look at my logs for me?
what blocks is it for cf's and mg air flow?
thanks again
Deleted member 39269
Looking good Gavin :D
Looks like your putting a lot of effort and work into it. Did you get the WOT box to work?
gavbey
THE SPARKIE
Oct 7, 2009
323
Perth / Lerwick
yeah bud the wot box is good, its hard with both the quick shifts and the 3200lb pressure plate.
i use the user interface on my laptop to set it to what i want its pretty cool.
Ronin225
4,652
22
Worcester
Just correcting an earlier post but LCR rods use 20mm wrist pins not 19mm (144x20)
Also block 003 for MAF readings and 020 for CF's
gavbey
THE SPARKIE
Oct 7, 2009
323
Perth / Lerwick
here is my logs,
i dont know whats hapening its just cuting out around 4k
any help would be apreciated
Code:
Group A:	'001
	RPM	Temperature	Lambda	Bin. Bits
TIME
STAMP	 /min	°C	 %
0.59	2680	78	0	1100000
1.49	2760	78	0	1100000
2.39	2840	78	0	1100000
3.28	2880	79	0	1100000
4.18	3040	79	0	1100000
5.08	3120	79	0	1100000
5.99	3200	79	0	1100000
6.88	3360	79	0	1100000
7.78	3440	80	0	1100000
8.68	3440	80	0	1100000
9.59	3080	80	0	1110100
10.48	2080	80	0	1100000
11.38	2000	80	0	1110100
12.28	3160	80	0	1100000
13.18	3240	80	0	1100000
14.09	3280	80	0	1100000
14.99	3280	80	0	1100000
15.88	3280	80	0	1100000
16.79	3280	80	0	1100000
17.68	3320	80	0	1100000
18.58	3400	80	0	1100001
19.49	3280	80	0	1110101
20.38	3200	80	0	1110101
21.28	3080	80	0	1110101
22.18	2920	80	0	1110101
23.08	2760	80	0	1110101
23.97	2480	79	0	1110100
24.87	2160	80	0	1110100
25.77	1880	80	0	1110110
26.67	1600	79	0	1110110
27.57	1440	79	0	1110110
28.47	1400	79	0	1100010
29.37	1400	79	0	1100010
30.27	1200	79	0	1100110
31.17	1120	79	0	1110110
32.07	920	79	0	1110110
32.97	840	79	0	1110110
33.87	880	79	0	1110110
34.77	1280	79	0	1100010
35.67	1280	79	0	1100010
36.57	1480	79	0	1100010
37.47	1600	79	0	1100010
38.37	1640	79	0	1110110
39.27	920	79	0	1110110
40.17	1000	80	0	1110110
41.07	960	80	0	1110110
41.97	840	80	0	1110110
42.87	840	80	0	1110110
43.77	840	80	0	1110110
44.66	840	80	0	1110110
gavbey
THE SPARKIE
Oct 7, 2009
323
Perth / Lerwick
Code:
Group A:	'003
	RPM	Mass Flow	Load	Ign. Timing
TIME
STAMP 	 /min 	 g/s 	 % 	 °BTDC
0.3 	1720 	19.89 	13.3 	21.8
1.2 	2120 	39.14 	100 	11.3
2.1 	2640 	73.97 	100 	3.8
3 	3600 	125.92 	100 	4.5
3.91 	4720 	160.58 	100 	6
4.81 	4760 	8.11 	3.1 	-1.5
5.7 	3360 	16.92 	3.5 	-3.8
6.6 	3160 	79.42 	100 	11.3
7.5 	3480 	127.56 	100 	3.8
8.4 	3880 	142.69 	100 	4.5
9.3 	4240 	150.14 	100 	4.5
10.21 	4560 	154.75 	100 	6
11.11 	4840 	155.56 	100 	6
12 	5080 	161.03 	100 	6
12.9 	4560 	0 	 2.4 	3.8
13.79 	2960 	8.64 	2 4 	12.8
14.69 	3000 	9.75 	2.4 	3
15.6 	3360 	19.61 	12.2 	37.5
16.49 	3280 	23.22 	13.7 	36
17.4 	3160	16.06 	10.6 	36.8
18.29 	3120  	23.86 	13.3 	33.8
19.19 	3040 	16.22 	10.6 	36.8
9,335
South Wales
Copy from excel and paste it between the CODE.
Thats actually not very good above, will look even better if you paste between the CODE option in advanced reply.
Jul 4, 2010
2,170
Cambs
Yeah, you need to paste straight from excel for it to format propperly, I just copied his post so It didnt work.
Gavbey, maybe get some boost logs too, block 115.
And when you log start from 2500rpm through to say 6-6.5k in a higher gear.
Also check your timing pull 120.
gavbey
THE SPARKIE
Oct 7, 2009
323
Perth / Lerwick
the thing is james when i put the foot down just past 4k it cuts out then has a massive backfire. if i use it mibey 75% throttle its ok.
i realy wouldnt think it would go to redline without cuting out bucking etc.
thanks for the advice. when i go home tonight i will log 115 and 120
thank you very much for youre help guys its much apreciated.
gavbey
THE SPARKIE
Oct 7, 2009
323
Perth / Lerwick
The thing is you have to log past the problem to actually see what is happening. Any fault codes?
Have you tried changing coils? Unplugging the MAF?
ok i see, didnt know that.
yes i get fault code
17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
i did have lambda problem but it was cleared once i instaled a new one and hasnt come back. but this one stays.
i bought new spark plugs last week BRK7EIX which are recomended i bought some coils also but when i change the coils with other spare ones i have the problem is still there
i havnet tried unplugging the maf either.
so tonight ill try:
unpluging the maf
and take those logs and i will report back to you guys what is happening,
thaks.
