flywheel is in at work but skiming the face is going to be harder than i thought!
bead blasting would give it a nice ruff effect BUT not necisarily flat!
need to get the dowles out to skimp the pressure plate lip also!
hope i dont have to fork out for a new one!
dam flywheel.
all coments welcome
little update,
installed my wot box,
sprayed bumpstrip
instaled new header tank
new 6x4" back box is here
new gearbox oil
still waiting for flywheel!
pictures of everything tonight
PICCCIES
£100 spare engine and gearbox with spare K03s turbo
my mot exhaust haha
Clutch update,
DADAHHHH
here is the whole setup
6 puck solid center stage 4 vr6 clutch with 3000 lb pressureplate and lightend and balanced 14lb g60 flywheel
here is comparison to the standard g60 flywheel
onnn
comments welcome
need to get out to the workshop to get my gearbox back in and do some finishing bitas and bobs
re-wire some abs bits
new windscreen
cut and weld magnex backbox on
put my x2 cats in for MOT
list goes on and on.
great work and great readers ride. 1 thing, have you uprated your rods yet as the wot box will bend the standard ones in no time, infact i give it hours. seen 3 lcr in the last month have this problem.
sam
sam
thanks sam,
well to be honest they are on my to-do list but i cant find them in stock any where. i want IE RODS. need the 20mm wrist pin type ( engine code AYP )
hopfully the rods will last untill i can find some.
:starwars:
May look into this as Im ready for a clutch and unsure what to go for.
Also, how did you smooth the rocker cover or did you buy it like that?
i smothed the rocker cover with an angle grinder and some chemical metal.
i went for wrinkle black paint but never worked out so a few coats of high build primer and white :)
