recommend good oil deals for pd130
attila_tdi
384
Hampshire
Going to do oil n filter on my pd130.
What oil would people recommend? Any good deals at the moment?
Also, do I need a new sump plug/washer or can the old one work fine?
Cheers!
spud31
Rail Zip User
Jul 14, 2011
407
TPS dude get quantum longlife 3. Get a new sumplug an washer always as these have a alloy sump
Sep 3, 2008
873
Buckie, Moray
Be best off to change the sump plug and washer, its only a few £ and cheaper than having to drop the oil again if it leaks or damages the threads.
I went for Mobil 1 ESP 5W30 fully synthetic oil that exceeds longlife spec, was £43 from Halfords on trade for 5litres I think
AndyC567
277
I use a Pela pump, can't beat it, can change the oil in your best suit !!
Simples, pipe down the dip stick hole, pump out the oil, quick filter change and the jobs done.
Can't recomend them enough, I was changing the oil every 8 weeks on my old Tolly due to a long commutte and it saved me fighting with the undertray, jacks, axel stands etc.
I did jack it up and drain it about every 3 or 4 times to remove any crud from the bottom, but never found anything dodgy in the oil at all.
In fact I find you can remove more oil with the Pela as you can use it to suck oil out of the filter housing to..
Fully recomended..
http://pics2.tdiclub.com/video/cincitdi/oilextraction.html
Sep 3, 2008
873
Buckie, Moray
Thanks very much. Where would i be able to get a sump plug and washer?
From your dealer or try Dave at SERE Motors on here, usually really good prices and quick delivery. I got my filter and sump plug from him
Where about did you get the pump from? Does it fit most engines or is the size engine specific?
AndyC567
277
If you mean the Pela oil pump, I got it from Ebay.. 25 quid delivered if I remember correctly.
The guy I bought it from was a boat dealer, sort of makes sense as how do you change oil on a boat, I would think the sump plug on an inboard lump is pretty inaccessable.
Really really good though, works a treat !!
I bought it after seeing that video link that I posted earlier, thought it was a good idea.
bald_eagle
yeah its blue but i like
Mar 25, 2007
528
yeah use a new sump plug and washer and don't over-tighten,use a torque wrench if you have one,
Sep 3, 2008
873
Buckie, Moray
Cheers folks. Think i will go for quantum longlife as mobil esp is £53 in halfords!
I dont mind paying for decent oil, especially when people say that the correct oil is crutial for PD130's and could also prolong the life of the engine. Try Opie Oils, they often have discounts or deals
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
I have one too! Amazing, so easy and quick. Its a Silverline one and cost me £18.
