Tucker157
1,065
Falkirk/Central Scotland
hey guys, im wondering if anyone could tell me what figures theyre gettin when logging block 002? and what i should be seeing on a stg1 revo, with a pipercross viper ind, ?
i only seem to be getting 80/ 90 g/s flow peak, which is very low isnt it?
am i right in thinking that g/s *1.331 = bhp? roughly? because if it does then im only gettin 120 bhp!!!! feel free to tell me im being stupid and have miss understood something ive read lol
cheers
Paul.
Intercooler pipes & vacum leaks, have you logged boost as well?
Maf can be baught from GSF, eurocarparts for aroun £80 exchange or main dealers too, ensure is genuine bosch.
yeh high 140
yeh the req vs acc, is here
req vs acctual.
1570 1080 @ 1480 rpm
1620 1180
1690 1280
1760 1370
1850 1470
1940 1580
2030 1710
2030 1870
2080 2050
2150 2210 @3080rpm
2200 2270
2240 2280
2240 2250
2230 2200
2180 2160
2150 2090
2140 2030
2090 1970
2020 1920 @4840rpm
1960 1890
1920 1860
1870 1840
1840 1840
1800 1810
1780 1780
1730 1770
1700 1750
1670 1740
1670 1710
1640 1680 @ 6200rpm
is this close enough? or is the difference too much?
Do you have full block, for 118 or 115?
block 115, full throttle 3rd gear run.
RPM Load Absolute Pres. Absolute Pres.
/min % mbar mbar
1480 72.9 1570 1080
1600 78.2 1620 1180
1720 84.2 1690 1280
1880 88 1760 1370
2040 92.5 1850 1470
2240 97.7 1940 1580
2440 103 2030 1710
2640 106.8 2030 1870
2880 111.3 2080 2050
3080 112.8 2150 2210
3360 112 2200 2270
3520 109 2240 2280
3720 104.5 2240 2250
3960 102.3 2230 2200
4120 99.2 2180 2160
4280 97 2150 2090
4480 95.5 2140 2030
4680 92.5 2090 1970
4840 91 2020 1920
5000 91 1960 1890
5160 88.7 1920 1860
5280 88 1870 1840
5400 83.5 1840 1840
5520 82 1800 1810
5640 80.5 1780 1780
5760 79.7 1730 1770
5880 78.9 1700 1750
6000 77.4 1670 1740
6080 75.9 1670 1710
6200 76.7 1640 1680
any comments? is it normal for load to be like that, is a tb clean/ alignment on the cards?
Hmmm seems ok but not much of boost spike, do other block to check waste gate duty,
but very certain maf is gone for them boost reading to create only a mx of 90 m/s
stage 1 g/s should be more like 150g/s-170g/s, 120g/s is std 156bhp car as a guide
deffo goosed the one you have in it..
clear fault codes and adaptions when you have fitted so it learns its new fueling again..
thanks for the help guys,
will get one on it as soon as i have cash, do i just reset the fault codes on 01 engine? or is there another thing to reset the adaptions?
how is the wastegate duty cycle checked on block 118? the load value?
cheers
paul
I have the same problem i am getting max 87 g/s ?? I have checked pipes ther are OK is the MAF or what?
But the car seems to Go good! My time on 402m drag was 15,4 without Slicks is this OK or?
I will do a log of block 118 and 115 later and put it hear if somone can help me pleas...
Its a stock engine it sould be something about 120g/s i think or am i wrong? I have a MAF from a leon 20VT 132KW is it the same or??? can i put this maf on my car??
