thanks, i can see you might be right on this, but all the links and pictures ar almost 5-9years old now and non of them seems to work now, so i cant see much.
so im still vary curious on this topic, i see some threads post 2 PDF docs where there apparently should be more on this, but again its old and no links works, those 2 pdf:
225-cae.pdf
225-1pt8.pdf
most i read is still pure speculation on some of the threads if you know what i mean, and some even say that the strengthening is "inside" so you cant see it on the block, like some water channel that is wider or got other shape at the top of the block.
but as what i can read if there is somethink that has additional strengthening, then im sure its not only the BAM engine, its probably also both the AMK and the BAM engine, and maybe also other 210/225 bhp engines found in other vagcars like S3 and TT.
so im still not satisfied with the result, i want more info on this but i know you cant do magic and get all my answer, but if you know or later get more info on this please let me know here or PM me.
