you could leave your valves and just lap them in but depends how much £££'s you got. i would replace EVERY seal, gasket and bearing! i'll be rebuilding mine in the next couple of months aswell!
re lapping the valves is re sealing them basically. using a couple of special compounds you put between the valve and valve seat and grind it in so that a good seal is formed so that you dont lose compression. might be a video on you tube that shows you how to do it. have a search
