Looks ace Dan! But your front discs are on the wrong sides :) no big deal, but you might want to change them before they bed in too much more
yea i agree with that, but usually the external grooves radiate outwards rather than inwards when the cars moving forwards, so any gasses or dust trapped within the grooves are flung out into the wheel rather than in towards the hub, suggesting that these discs look unusual.
Another point to note, is that vented discs 'draw' air from the centre behind the bell and expell air from the outter edge again, hence why when you see race cars with brake cooling ducts the ducting goes to the centre of the disc on the back face so it's drawn out through the void between sides of the disc.
So i guess the simple question is, do the vanes inside your discs go in the same dirrection as the grooves on the outside?
If the internal vanes are in the same direction as the external grooves, then they're on backwards, if the internal vanes are in the opposite direction, then they're unusual, but correct.
I'm more than happy to be corrected, but I made this exact same mistake a while back and was corrected, so i did a bit of research into it at the time.
This pic from the AP website shows what I mean perfectly
The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Orienting the disc in the manner creates a centrifugal pump.
The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat.
The vains point towards the back of the car and the groves on the disk face towards the front I did ask the same question when they was being fitted mate as thought it was odd
Very strange! Was just checking mate because I made that exact same error.
So long as the internal vanes are right then all is sweet :) it is unusual though
Looking mighty fine :) The K-sports are all like that and I checked with Bren @ K-Sport when I first got mine, so you're not on your own.
The black Leon linked from eBay is only up the road from me, and has serious road presence; Christ knows what yours must be like with wider wheels, a wider footprint and much lower!! Awesome stuff.......get the dash flocked sharpish ;)
Ah really where you based and do I need to take the dash out
were based in somerset mate yeah if you take out ther bits u want doing and get them to us we will courier them back to you pm me a list if u want and ill work some prices out for you
Erm getting wheel bearing done tomorrow , and I'm just at lakeside going to book milltek down pipe and stage 2 map so kinda lol
Brakes are immense
Yer can't wait mate , car made 213gs on the liquid not sure if that's good cant wait to see what the down pipe is like should be good I hope
Around 266bhp using badger bills method of estimating bhp from airflow readings mate
