Hi, and Merry Christmas people!
I have just fixed my limp mode!!!! but.....
I am looking for a good regular use product I can use to prevent my turbo and the actuator from clogging back up with carbon. Does anyone have any ideas; will standard Redex treatments or Wynn's diesel smoke products help and if so, how often do you think they should be used?
I've spent the last 3 months trying to fix limp mode on my Seat Leon 1.9 TDI and tried a whole manner of things to no avail, although i must admit the things we have done will obviously have a positive effect on performance and maintenance. I recently purchased the Innotec 3 stage turbo cleaner which (touch wood!) has done the trick and we also free'd up the actuator in the process. Although this was success, i would much prefer not doing this 3 stage clean again any time soon as it was a real bind getting the turbo pipe off as it is located at the bottom of the engine and was a bit epic to do! although i admit once free the actual treating of it was easy...
any help on what product and frequency would be most appreciated as i would like to prevent this happening again
i highly recommend the Innotec product to anyone having troubles by the way because it solved my problem (hopefully!)
many thanks
many thanks
Hello...
