Right,tried cleaning jet with a pin,then a guitar string but no joy.Removed hatch trim to find a small amount of fliud leaking from the connector that fixes to the motor housing when trying to wash the rear window.
Unclipped the hose from this connector and a strong flow squirts out.
Priced a new motor £77+vat, but now noticed that the carpet behind pass seat is soaked with screen wash.
Is it possible that the washer pipe has split due to the blocked jet ,and how do you remove the plastic trim to gain access to the washer pipe to check it .
Or would a new rear motor ease the pressue if the pipe is split,making the leak more of a drip,if you know what I mean.
