Maybe this is one of many threads about this, but I can't seem to find the answer I need...
As the cold weather has really started to set in, it's time to start using the rear heated window. Now the switch on the dashboard lights up, the fuse is fine and the heated wing mirrors de-mist, but the heated rear window won't demist at all none of the elements work).
A couple of weeks ago I bought some of this granville conductive paint/window demister repair kits as I found a couple of breaks in the lines/elements. I applied the paint into the gaps, left it to dry but it hasn't helped. Today I found another 3 breaks, right at the ends of some of the lines/elements, all on the drivers side of the window.
So I thought I'd better try a bit of fault testing with a multi meter... In resistance mode, I tried touching the probes on the two small areas, that I repaired with the conductive paint (bear in mind that these two points are on opposite ends of two different elements), and I got a resistance of about 0.9 ohms (I'm no electrician, but I think that's pretty good?). I then unplugged the two metal lugs from the rear window from the sockets on the tailgate, tested the resistance across these 2 and got a reading of about 80 ohms. I also tried probing the parts where I found the 3 new breaks (2 at time of course in different combos), and the resistance was again about 0.9 ohms...
So, is it likely that these 3 breaks can cause a high resistance across the whole grid? I thought if an element was broken, just that element wouldn't work? I'm just curious if any one knows if having a few elements broken means the whole rear demister won't work?
Sorry about the long post, but any help would be most appreciated!
