Cupraboy4
CUPRA TDi
Mar 20, 2006
281
WEST MIDS
Hi all,
since the tiny little frost we had a week ago my rear washers wont work? i can still hear the pump pumping away but zero water comes out, the front still works fine and before a 'smart arese' says 'fill up the water bottle'... i already have :confused:
any idea's??
thanks,
carl
Maybe the pipe has popped off, And everythime you try it your just filling your boot with water. Ive heard of them popping off on the ibiza
Hi all,
any idea's??
thanks,
carl
Same has happend to mine, i little trickal of water (and I mean little) comes out. I have tried cleaning the hole with a pin but no joy. So I can only think its the internals of the jet.
My pipe split (it's wrapped in black tape up the left had side of the engine bay)
Mine didn't stop working but was only about 60-70% of what it should have been, I only noticed as I had the bonnet up whilst washing the rear window and a jet came out of the engine bay and went about 4-5ft.
The problem is the pipe itself is ribbed, and very hard to get to (it's wrapped with the front washer pipe and a small wiring loom) I wrapped it in PTFE tape and it's alright, but not a good fix.
It did also pop off, but I too didn't get a wet boot - I think the water finds a way out without making the carpet wet. Check behind the right hand side trim.
