Sticky door handle
Joe M
Newbie
Jan 31, 2002
22
Glasgow
Visit site
Alrighty, the outer passenger door handle on my missus Ibiza occasionaly sticks out when opening the door, preventing the door from shutting properly if not noticed.
Its still under warranty, so could just take it to the garage, but if its as simple as spraying some WD into the handle or something it saves a trip.
Nov 23, 2010
873
Dunfermline, Fife
Id probably use a light emulsifying oil..they type that dries white..
Its just dry, not worth a trip to the dealers unless its 5 mins away.
Just my 2p worth. ;)
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,303
7
Desborough
+1, I had the same on the boc and just sprayed some penetrating lubricant into the handle and it was fine after that.
Aug 3, 2011
1,357
Mines just started doing it, driver side perfect? even trying to make it stick it doesnt, but passenger side is more inclined to. werid. Will give the lube a go JC ;)
aha
jc_boc
Jul 18, 2008
9,303
7
Desborough
aha
:lol: I don't need to know about your wierd things mate hahahahahahaha
May 19, 2011
639
to add my 10p worth got 5 door ibiza and they all do it tho drivers side not as much ill take advise from above. Is wd40 ok or bad?
G3K
3 points and counting...
Aug 14, 2010
451
Hatfield, Herts
My wife has a Nissan Micra and that was suffering with sticky door handles, used WD40 on that and it worked a treat. Bonus is it smells great but I know some people would agrue about that.....
Fusster
148
you can lube the handles for a temp fix but this is a recognised problem,there is technical info on it,there is a modification that can be made(remove the handle and shave a small amount of plastic from part of the handle).if one sticks they can all be modified under warranty F.O.C....
