sherif2005
Hello mates
i am about to install a license plate backup camera in my ibiza. as i understood from several videos i watched. the power of the camera should be drawn from the wire that's feeding the reverse light (the camera will be on when i am reversing) so i was wondering which wire is feeding the reverse light and which is ground? a popular choice for that is blue black wire for power and brown for ground, is that true?
thanks
On my 3Dr. it was Blue/Green for the live.When you look at the light cluster with the reflector off you can follow the track back to the plug which i guess you will have to access to wire it in.
Put your reverse lights on and use a test light to check for power at the plug, the live one will be the one you want.
reverse camera
Hello mates
thanks
what camera did you get? where from? how much?
im looking for one at the moment.
cheers
toejam237
reply
i got it from amazon.com not amazon.co.uk, it is very cheap across the pond. i think it costed 14 u.s dollars and i had a friend pick it up for me when he comes.
i read a review of a parking sensor getting fitted and it seems you are quite right mate.
blue-green for live 12v
brown for ground
i am just waiting now for my double din to arrive to get everything installed.
