liamjd1900tdi
Hi everyone,, I'm planning on fitting a cambelt kit on my 02 reg Leon in the next few weeks just wondering how difficult it will be ... Any advice will be much aprisiated.
Thanks liam
Thanks liam
yer, not something you really want to get wrong.
should cost in the region of £300-£350 with a water pump if you got to a VW specialist and not a main dealer.
£300-£350 seams a tad expensive to me![]()
I'd say that's pretty much a standard fitted price. Main dealers and your looking at £400-£500
Which engine, PD or non-PD? At a flagrant guess, since you say in your profile it's an SE, you have the TDI 110 engine which is non-PD, i.e. a ditributor pump diesel with hard fuel lines from the pump to the injectors.
The toolsets are different for PD and non-PD engines, and on the non-PD you have to lock the pump and the camshaft. There was a thread about the special tools not so long ago.
On the other hand, if it is a PD engine (TDI 130 or 150) check the exhaust valve lifters and cam lobes for wear. The so-called "chocolate cam issue" afflicts the PD engine; - the addition of the PD cam lobe means that the exhaust and inlet cam lobes are narrower than usual, and these drive the requirement for a special spec of lubricating oil, VAG 505.01, for PD engines. If non-compliant oil has been used, the cam lobes and lifters wear and eventually fail.
Quick question is kwik fit a recommended place to do my cambelt? Or are they known to do the job wrong?
Cheers lads I'm definitely not going to go there, can anyone recommend a good reviewed vw specialist around the west midland area to change my cambelt and water pump I have £500 to spend on this?
