Ah i see, still a good result though. You can afford to push yours with confidence with those rods fitted. Get some logs up for some obs when shes running sweet again. the cage sounds hardcore and will add to its aggressive stance.thanks mate it should be back on the rollers once I get the manifold fitted , I don't think I had a boost leak tho as its a one way check valve so only flows one way , just didnt have the wmi connected I think it was for the 1st run as it made more power the second run it made less , need to order my maf this week as well
To be honest with you mate I haven't used it for a long period of time I tried setting it up it sounded awesome so much louder than the split r and 007p but it kept putting my car into limp mode so gave up lol will try again when I have more time , thanks for the comments i like to be different
