Guys,
I'm doing a guide of what you need and how to install along with some photos. I forgot to take them during the making process however I'll take a photo of the back of the vent which shows what to do. This will be done this week, hopefully tonight!
If you have general DIY bits'n'bobs at home then you can do these for under £15! :)
Guys,
Excellent! Looking forward to it, and it as my next cheapy mod
Guys,
Looking foward to it :D!
Pics pics and more pics please :)
Saw these on ebay awhile back
This looks very nice. Not too small LED's either. Noticable yet discreet. :)
Also a unique DRL look (possible due to the BTCC grille design), compared to the generic "Audi DRL" line of lights you often see on cars on the road.
Finally managed to get some photos and a guide however like usual I didn't take any photos whilst in the process of making them therfore there is a longish step-by-step explaination and some photos after. If anyone has any questions just let me know and I'll try and explain. Also, mine is a 58 plate just in case you are wondering.
I got some usuful ideas from this link http://www.youtube.com/watch?NR=1&fe...&v=Jx-jhpMtiUM but as its Spanish I decided to give it a go myself. Also, mine are waterproof as there are no issues with all this recent rain!
Most of the below items I had around the garage, the only things you will probably need to buy are the SMD's, Glass Cabochons, black sealant and Fuse Piggly Back.
I've put the ebay name to search for, the seller and the price so you know what to look for. There are other sellers out there so feel free to go to who you want!
Items Required
•A Circuit Fuse Tap Piggy Back Standard Blade Fuse Holder - £3.20 - autostar*
•Clear Glass Cabochons Cabs Flatbacks Oval Round Square Image Magnifying 10mm round x2 - £2.00 + £0.90 postage. Marmaladeblue
•2x ERROR FREE CANBUS T10 W5W 501 Car White 5 SMD LED x 2 - £5.94 (for 12) - delhanway2009
•Clear Silicone Sealant – Screwfix no nonsense £2.59
•Black Silicone Sealant – Screwfix no nonsense £2.59
•DVD case (perfect match to the vent plastic).
•Superglue
•10mm drill bit
•Needle File
•Soldering
•Black flex cable - 3m
•Scissors, cable strippers, spanner etc.
•Cable tie
•Insulation tape
•Cable blocks
•Cable fixing earth hoop.
•4 Amp fuse.
•Multi-meter (to check fuse power location)
How To Make:
Simply remove the three retaining Philips screws (top, middle and bottom) and slid the vent out towards you as there are a couple of retaining clips to the front of the vent. Incidentally, this is how access to the fog lights is obtained from!
Give the back of the vents a good clean to remove any dust which could affect the bonding of the glue. Now get the DVD case and cut it into three separate sections which are big enough to cover the holes in the 3 sections using scissors. You may have to do some trimming here and there to get them to fit in place but you will see once you get started. Hold them in place (some tape will help) and then look at the front and mark the middle of the vent holes. Remove and then drill the 10mm hole in each with a wood drill bit on a slow speed, make sure you grip the plastic tight! Once drilled use the file to remove any sharp edges etc. Note: the second from top SMD is quite close to the vent fin, just make sure you cut the hole in the right place.
The glass Cabochons should fit in the holes perfectly however make sure you use the clear silicone to stick them in place on the inside of the vent and make sure that you stick the smd onto the glass at the same time, you don’t need a great deal of silicone and this also provides the waterproofing. Once dry you can cut small sections of the black flex cable (about 15cm long) and pull out the brown and blue inner wires and solder these onto the ‘+’ and ‘-‘ parts of the smd (be sure to have about 4 inches of wire so that the can get past the screw holes when refixing the vent back to the car). Make sure you check which is the + and – with a 9v battery just to be sure! Once this is all done you can connect all the + and – together with a cable block.
Apply the superglue to the back of the vent not using too much as it will squash out and then press your DVD/smd case to that making sure the smd’s are in the middle (apply the glue to all parts of the vent so it holds firm), hold it in place as the dvd case will flex to the shape of the vent so no gaps will be seen. Once dry (about 20 seconds) apply black silicone over the back of the smd and edge of the dvd case to give a waterproof seal and stop any light shining into the car body.
Feed the black flex from one side of the car to the other and cable tie it onto the inside of the under skirting behind the middle vent/mesh…there are a number of places to connect it to but you need to get on the floor to reach under. Connect the + and – to the driver’s side block on the completed smd vent and put tape around to protect it. Leave some slack so you can always access them if required.
Do the same to the passenger side but also remove the blue/brown section of flex which is long enough to feed up to the fuse box. Add a metal loop to one end of the ‘-‘ and fix to the bolt on the body. Connect the ‘+’ to the piggy back fuse holder using a connector and then use a 5 Amp fuse in the connector and plug this into fuse location F22. Screw the vents back on and all is done.
The lights will only come on with the ignition and once you have completed your journey they will stay on for about 10 mins after which are useful for ‘coming home lights’. As the power usage is so low you won’t have any issues with the battery going flat!
Things I would/will look at changing:
Adding some sort of frosting on the back of the Cabochons so that when the lights are off the green/yellow of the smd doesn’t show through. This is just me being picky!
Checking other sources of power which may only stay on for a couple of mins when locking the car or even straight away as I've already had two people coming up to me saying that I've left my lights on!. If anyone knows which fuse this is please let me know as it will save me time fiddling around at the weekend with the multi-meter!
Photos:
DVD case sut to size (cut around the screw holes etc.) and then glues in place. The silicone covers the SMD's to make them waterproof.
Side profile. You can see that the DVD case has the flexibility to follow the profile of the vent.
Make sure you don't block any of the clips with silicone otherwise you will struggle to get it back in.
Lights off.
End of '-' earth cable connected bolt on body above passenger headlight.
Piggy back fuse holder in F22.
Off....not really noticed.
On....just lisk a DS3.
At night (rubbish photo...sorry, thats an iphone for you!).
Close up when on.
Side view at night.
Reactions: zamzia
Cheers for the guide, really helpful. Can I confirm where to get the black wire from and also the blocks/hoop?
Finally, Can I just double check that what you have done is glue the outer edge of the 501 bulb face to the outter edge of the domed 10mm glass? and then covered the rest of the bulb in black silicon to hide the bulb/connection from the air/water?
Also, I'm guessing the for the wiring you have put the 6x - and 6x + wires on the drivers side into a block and then run 1x - and 1x + wire from this to join the block from the passenger side? and then just run the single wires from this to the fuse panel and the earth on car(loop)
Is there already something in F22 and what is the 4amp fuse for?
Looks great, gonna be ordering bits soon.
I had a load of black wire at home but you can use the blue wire from the length of flex. The hoop was in a small set of fuse/car bits I had at home however they are easily available from halfrauds, ebay or even poundland. You can always just strip the wire and wrap it around the bolt but useing the hoop makes it neater.
Blocks are also available from halfrauds, diy stores etc. its the basic ones that are joined in a line of about 10 and you cut off the amount you need.
Use the clear silicone on the face of the smd and stick the glass done onto it. This also acts as a waterproof seal. The back of the smd (where you solder the wires) is covered in the black sealant, again to waterproof it. It also stops any light getting into the front body panel and trying to make it glow!
Correct :D
Yes there is as some of the empty holders had constant power even when the car was off, to be honest I need to check what F22 is but its only a 5amp fuse and you put that in the piggy back holder with a new fuse for the SMD's in the top half (i.e. 3/4/5 amp but I used 4 as I had a spare one). The power that the SMD's ise are minimul...I recall working out that a 1.5amp fuse would be fine.
As I said at the bottom they lights stay on for about 10 mins after so I'm going to get the multi-meter out and see which ones stay on for just a couple of mins
Let me know if you need any other info.
Rob
that looks top class. My vents are different so would need to work around this some how lol. Just hope I have the brains to figure it out.
Amazing stuff..
Can I be a total n00b and ask for a diagram of the actual light "module" you made?
Just to see how you wired it all up.
I'm sure you can sort it out...the way I did it is that they can be removed without causing any damage to the original vents.
If you take a photo of your vents I can always give you some ideas/suggestions?
Rob
I have both types of vents, I have just taken ones off like yours and put on the Linea R style ones, looks like I'll be going back to the style you have again now :)
Would be interested to find which fuse will keep lights on for less time.
Thanks very much for all the guides :)
I'll get the multi-meter out at the weekend and see what works best. The strange thing is that if you don't start the engine the lights go off after about 10 seconds but once the engine has started they stay on for about 10 mins.
Will update once I've had a go!
i would also like to know answers these questions. also is there another way where you wouldn't have to solder?
