Demon tweaked
57
Sup guys,
I have been on here for a while but hardly post, i had a rides thread somewhere but just cant find it right now. heres my pride and joy.
PTE 5858 BB Turbo
PTE 39mm External Wastegate
830cc High Impedance Injectors
Calico Coated Rod bearings
Calico Coated Main bearings
Custom Branch and Manifold by Lee at gtec
IE Rods
IE Gasket set
JE Pistons 9.25.1
JE Piston rings
ARP Rod bolts
ARP Crank Damper bolts
ARP Head Stud kit
ARP Cam Pulley bolt
ARP Flywheel bolt kit
Custom Surge Tank
VR6 Copper Clutch and ABF Flywheel
Custom Catch can
Bosch 044 Inline Fuel Pump
76mm Custom DP
Eboost 2 EBC
Motor Rebore to 1.9 (Sarel 8v performance)
Headwork by Mike Dixon in CPT, Recon, port polish, flow, oversized billet zorst valves etc
Custom boost piping
WOTBOX
NGK Plugs
Devils own DVC 30 WMI (Dual meth nozzles)
Battery relocate to boot
Poly engine mounts
H&R Suspension
Forge Intercooler pipe
Forge Short Shifter
Forge 008 DV
Digital Designs Amplifier
JVC USB Front loader
Unitronic Stage 3 Software (big turbo custom tune)
IE Rods/ARP Rod Bolts
Calico Coated Bearings
830cc Injectors
Oil Catch Can
Bosch 044 In Line Fuel pump
39mm PTE Ext wastegate as well as ARP head Stud kit!
JE Pistons
ARP Cam pulley bolt, ARP Flywheel bolt kit, ARP Crank Damper bolt
Calico Main Bearing set
all the goods together
before
after
Some pics of the branch being made, turbo position, heat wrap etc
Done!
So heres the DP and the screamer pipe
haha, yeah thanks! Hoping to get her back today or tomorrow. will run her in for a while but try get those videos! thanks bro
thanks bud!
I gave it to a friend to do who is a proper DIY guru so to speak, he used a heat gun and said that each light took about 2 hours to split!
update car made 393whp and 485nm on a run in file.
Awesome build so far! Is it comfortable to drive on the road? Any thoughts about LSD or anything? A relatively small car with all that power must feel brilliant...
Look forward to hearing more about your build progress :)
thank you bro! The poly engine mounts are extremly stiff which was annoying at first because on start up every thing rattled, from the dash, to the windows to the sunroof. I think they are loosing up though or maybe i am getting used to it but it doesnt seem bad at all. she drives very nicely as well and when power is needed its there. Fuel Consumption is very low as well, lower than when i had my stock turbo in.
Will try and get dyno vids up soon. Thanks again man
Impessive stuff, what we talking when its on a proper map after its been run in?
Not sure Copey, the goal was 400 but i got 393whp on pump fuel without tuning. Maybe 450whp if i had to guess? :clap:
aah sorry i meant to respond about the LSD but i forgot. ;)
I plan on getting LSD soon as well as stronger sideshafts, I dont know when that will be but hopefully soon. I also want to get NOS soon if I'm brave enough when the time comes :rofl:
Woah! You don't have a diff? I struggle with mine at 240 bhp so you must literally have to wrestle yours round corners :lol:
I have plans for a diff before I go for more power, it's just with our box the only off the shelf option is peloquin and they are close to a grand :(
haha yeah, i have come out of bends sideways a few times. Im not a big fan of taking corners as a fast as i can, i prefer my straight line stuff.
Peluquin, Quaife and Wavetrac offer solutions for us, check it out :funk:
