BBoy82
Dan the compressor man...
Oct 25, 2008
293
East Northants
My belly pan/sump guard has finally bit the dust (after being held together by cable ties for a week or so) in the wake of hitting a rabbit @ 90. :lol:
Is it worth replacing, given the fact a new one is £63 from seat, or should i just can it, and not bother replace?:confused:
Any advice would be greatly appreciated!!!
Dan
the crappy little plastic thing underneath?mine never been on since i done me 1st oil and filter change.to much of a faff on.only adds weight and slows you down!! :lol:
It's there for a reason. Airflow, cooling, sound deadening etc etc. I think its expensive for what it is to look at, but £63 aint that much overall. Have you tried a breakers yard ?
I would, i find at speed the car is alot smoother, imo it reduces under car turbulance. If i lost mine, id try and find one from a breakers. Other than that, try piecing it back together with some strips of metal and rivets and then get a nice powerful soldering iron and plastic-weld the endges back. Thats what ive done on the pieces that hang down from the chassis legs around the intercooler/drive belts.
As above, get it, it hass ducting for the clutch and Gear Box to cool these and should help with high speed runs. This will stop big things getting up into the engine bay aswell. Like rabbits;)
.....and tractors. I reckon that when I did a test run on mine without the guard on it must have sucked a tractor up cos it sounds just like one, especially first thing.
Plus there is nothing worse than having to keep opening the bonnet to pick all the Civics, Fiesta's and Minis out from the engine bay!! A guard helps ensure that they pass to the rear and are left in the dust.
PMSL!:cartman:
yh you should get it replace IMO as mine fell of the other day and on the motorway my MPG seemed to have dropped down a bit, not sure if thats just a coincidence tho (its back on tho now)
Nice one fellas! Thanks for the swift replies!
I'll get it on order straight away...
Normally £63 quid aint an issue, but im getting married in july... You can imagine!
Cheers, and all the best.
Dan
What part is it on this pic?
I only have part number 1, looks like there should be a second section to cover below the sump, is that right?
My Belly Pan / Sump pump has now just decided to fall off. Just wondering if anyone has any ideas where you can get one as i have looked on ebay and nothing is available atm.
Matt
It's an undertray, a sump guard would be heavy metal and rigidly mounted to the chassis.
In the ETKA diagram above, the short undertray is the one for the petrol engined cars (apart from the LCR) and the long one is for the diesels. The diesel undertray has a secondary sound-deadening function.
Undertrays improve the car's aerodynamics, smoothing airflow under the car and helping to ensure that the engine bay is a low-pressure zone, promoting airflow through the radiators. They also keep stones and water from damaging the car's electrics and the low-mounted boost pipes on turbo cars. Well worth having, I think.
The LCR has a special undertray, full length and with NACA ducts. The TDI 150 also has a special undertray, as I've just found out - it seems to be thinner than the ordinary TDI undertray, presumably because the 150 Sport is 15mm lower than other Toledos, and to have a dished area below the turbo.
Comparative pictures here.
TDI 150 undertray. This one is damaged (previous owner hit a rock from the look of it, ripping off the back edge and some of the side mounting points). The oil is from the boost pipes, which get it from the PCV system, recirculating crankcase vapours (which are of course oily) into the inlet system.
TDI 110 undertray.
As you can see, the diesel undertrays don't have a hole under the engine sump, despite what the ETKA picture seems to show.
Get one from any dealer, parts supplier such as GSF or from David at Sere motors, one of the forum sponsors - see the sections below.
Never seen one of these on my mk1 LCR, has anyone got [or can take and post] a photo of one of these, ideally from a mk1 LCR.
I fancy one of those alloy ones that folk are making, save whacking things with the sump and it should last longer than the plastic one.
