how long do your tyres last?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Just replaced my front tyres 02/2011, with toyo proxies 16"
other week checked it and they on the limit.
I do poke odd occasions when im in a rush, :rolleyes: i was hoping they would last longer as i think the part worn continental i had would last longer. gettin expsensive changin them every year...:(
how often do rest of you change yours? (not inc track day use :p )
Big-Pete
Always on the Limit
Aug 8, 2010
2,969
4 wheel align if you can using a hunter machine.
i bought my car in april and will need new tyres in august/there abouts.
they where almost on the wear markers anyway, highly recommend pirrelli Pzero nero reinforced tyres!
Tucker157
1,065
Falkirk/Central Scotland
I run pzero Nero's n I've put two full sets on in 16 months. Still life left in them tho, n I've done about 20000 miles in 16 months, so, I think that's reasonable, I'm not a granny after all!
But I had proxies on my 1.3 polo, n a Full set lasted me 4000 miles! Hooning obviously, but they are soft!
Sent from my HTC Wildfire S using Tapatalk 2
Big-Pete
Always on the Limit
Aug 8, 2010
2,969
p zeros are awesome tyres i really rate them what do you think?
Tucker157
1,065
Indeed! They do the job well, wet or dry, very good feed back and very progressive when on the limit, but 85 a corner can get pricey when you tear em to shreds, or get a bit of wire through the side wall in two places on a tyre with 5mm tread! (which just happened to be btw!)
Mar 19, 2010
740
derbyshire
I get 12000-15000 out of my Toyo T1r's and had 18000 out of my uniroyal rainsport 2's, I dont drive steady all the time as I go to Santa Pod quite afew times a year, £60 a tyre for that amount of miles sounds good to me ;)
Aug 29, 2010
587
suffolk
i used to have uniroyal rainsport 2's then tried p zero's going back to rainsport 2's they last longer and grip alot better in my opionion p zero's didn't last long either i don't drive fast all the time or slow all the time drive the car for what it is built for :)
JacketJ
105
Hampshire
I'd always had Proxies on my old Mk2's but just put some P-Zero's on the Cupra R and they seem ok. I thought the proxies definately seemed better, especially in the dry, but I only used to get around 6-8k out of them. Will probably go back to proxies next time unless these really last much longer.
Tucker157
1,065
pzero nero should last longer then toyo proxies, proxies are only good cause they are soft! pzeros are a good compound of rubber, not just a soft one. proxies hold on good but they tend to 'snap' free on the limit, youve got grip then all of a sudden its sliding, whereas with the pirelli's i find them very progressive!! they just gently let go. and allow you the feed back to catch it. id like something with more outright grip but to get such a well balanced tyre the next step up is quite expensive!
Tucker157
1,065
Gsd2 or 3 n now they do a asymmetric one aswell I think.? I know the original 1 was awsome, I thought 2 wasn't as good as 1 and wore out more quickly, but haven't tryed the other two,
