I fitted Weitech coilovers a few months ago due to my top mount bearings failing and driverside spring snapping. I replaced all the top mounts and bearings at the same time but I still occasionally get the boinging clonking noise of the spring rotating when I turn then wheel, usually only when Im turning to full lock. It sounds like the passenger side. Ive only lowered the suspension about 15-20mm as any lower and I would break something on the crap country roads on the way to work.
Is this normal and if not what should I check?
