dazjstuart wrote
You dont need that expensive stuff, stuff like this works http://www.ebay.co.uk/itm/Double-Si...A%2BFICS%2BUFI&otn=21&pmod=170857763974&ps=54 1 roll of that did all my doors with quite a bit to spare. You can get it cheaper than that in b&q or what ever with no postage. The stuff above in the ebay link will definatly work though.
That is practically identical to the foam tape that was originally fitted to the doors and has failed. It's proven to cause problems after a few years. VAG themselves changed the seal to the non-setting butyl compound.
Foam tape will just leak again after a while. Don't waste your time with it.
