fahafiz
231
Hi all
I have a leon, 110 asv. It has 107k miles and I religiously service it every 5000 miles but the engine is getting louder. How can I make it quiet?
I think it's easier to get better sound proofing for the cabin. dynamat? But if the sound volume has increased, I'd worry something is wrong.. :(
Was always getting louder even before the tune
I think, and I think, the alternator tensioner is getting louder. Hmmm
I'll research sound proofing. Any other tips? Additives?
Is the aux belt tensioner bouncing when the car is idling?
Also a common one for noise is the fuel pump
Won't mineral oil cause damage in fuel
Tank?
The belt ain't bouncing but it's making a notice.
Seatmann wrote No he wont and he doesn't need it anyway DAD
"Air Pollution from Motor Vehicles: Standards and Technologies for controlling emissions", Asif Faiz, Christopher S. Weaver, Michael P. Walsh, 1996, The World Bank, ISBN 0-8213-3444-1
P 96
"Some of the requirements for a catalytic converter to be used in two-stroke engines include high hydrocarbon conversion efficiency, resistance to thermal damage, resistance to poisoning by sulphur and phosphorus compounds in the lubricating oil and low light-off temperature"
The catalyst in our TDI engines has none of these properties.
Two stroke oil is a lubricating oil and not a fuel oil: it contains additives not found in fuel. It does NOT burn cleaner than diesel. Most of the two-stroke oil you can buy today is meant for engines that do not have a catalyst: chain saws, strimmers, hedge-trimmers and the like.
Oxidation Catalyst Performance Considerations: Catalyst Temperature, Space Velocity, and Fouling
Presented at the 2011 Gas Machinery Conference Nashville, Tennessee
Daniel B. Olsen, Engines & Energy Conversion Laboratory, Colorado State University
Gregg Arney, Southern California Gas (SoCal)
Arthur Reining, Stationary Emissions Control, Johnson Matthey
Introduction
"Catalyst poisoning is attributed to sulfur, phosphorous, zinc, and calcium compounds. Sulfur
normally originates from the fuel and is significant in low grade diesel and some gaseous fuels, such
as digester gas. Phosphorous, zinc, and calcium compounds come from lubricating oil. Catalyst
poisoning from sulfur should not be problematic for engines operating on natural gas and diesel fuels
that comply with current sulfur standards. However, compounds from lubricating oil can cause
significant degradation in catalyst efficiency, even in 4-stroke engines with no cylinder lubricating
port2,3. For integral two stroke compressor engines with cylinder lubricating ports catalyst poisoning
from oil derived compounds is expected to be more severe."
That's just a couple of quotes from the first page of a google search. There is a huge amount of additional data out there, all of which says that two-stroke oil in fuel will damage a conventional catalyst.
Catalysts can be applied to two-stroke engines, but they are radically different from those on our TDI's.
Now, it is true that at present the oxidation catalyst on diesel cars is not tested at MOT, the only test applied is a smoke test. I still feel that owners should be aware of what they are doing when adding things to their fuel.
A bouncing tensioner usually means the alternator pulley is bust, they have a one way clutch built in but if the seize up the tensioner starts bouncing like an idiot on idle.
Muttley, the Americans have mad laws for emissions yet they use 2 stroke no problem at all, the amount we're talking about is far to tiny to cause any issues at all. You can see why I called you dad though? You come in all serious and ruin our fun lol :D
Haha muttley is cool
So, how should I quieten my engine?
Should I change the noisy tensioner ASAP or let it die first?
Sorry I had to Join in with this convo I have put two stroke oil inp my Cupra tdi and I have made a thread about what I have noticed hear
http://www.seatcupra.net/forums/showthread.php?t=359004
And also hear is a link in how it works
http://www.brick-yard.co.uk/forum/adding-2-stroke-oil-to-diesel-tank-read-this_topic37935.html
Muttly the fact of a cat on the diesel engine getting blocked or damaged due to using two stroke oil ain't really a worry due to the cat on diesel engines are not really what we should call a cat it's more a sut cleaner.
The cat on my tdi is a completely diffrent internal construction comperd to its petrol counter part.
Myself from what I have read up and tests I hve carried out I have not found any reason it would or will damage my cat. I have smoke tested it with the 2 stroke oil mix and without the mix and with the two stroke oil mix my emissions where a lot lower.
