Done, Thanks very much. That's much better.
Should have been that way from the factory.
I never look at my main speedo now I always use the digital.
When pulling away fast from a standing start it jumps up 9 mph at a time
Found it
Step 1: Connect up to VCDS/VAGCOM in the usual manner, then select Instruments under the Select Control Module menu.
Step 2: Select the Coding sub-menu
Step 3: Select Long Coding Helper
Step 4: Select Byte 0 Bit 4.7 drop-down menu then select 10 Country: Rest of World (RoW)
Step 5: Exit Long coding helper then hit "Do it"
That's all you have to do on VCDS/VAGCOM but now you will have to change your MFD Settings, Units menu to the correct UK format from US format (imperial to metric).
Step 6: Un-tick the Alt.speed dis to activate the "Alternative Speed Display"
Step 7: Final stage - Change your units for Consumption to MPG and Temp to ˚C.
In VCDS
by law you have to have both MPH and KPH...ive only got MPH now
nope this isnt true as Civic's have a switch for it to go between the 2
That's the point though, they can still see KPH if they want. With the Leon's system, you can't.
after you have set it up you only have to tick alternative display to get it back so i consider that the same as the switch![]()
The switch is there to make it legal, you can switch it back to KP/H at any moment
We cant now we need to physically log into VCDS
Don't need to have VCDS mate just tick alternate display and its back to normal![]()
Hence why i edited my post above![]()
unfortunately if it was set by factory it would be illegal due to not having KPH on clocks
im guessing this option is for Spain etc who have KPH Clocks
I think the legallity is though that you must have KPH displayed at all times, if SEAT gave you the option to set it to MPH it wouldnt of been allowed.
Not sure but who cares we have all got it now
