do i need to take off the rear hub and rotar and wheel bearing etc, basically just complete dismantle the rear hubs just to get these rear splash guards off ?
Fraid so :(
When i did mine i changed discs,pads & abs sensors at the same time
so axel nut, then a puller tool to remove the bearing and housing with the abs rotar, then undo them 4 axel bolts :censored:
would all these need replacing with new ?
2 x rear hub nuts
2 x rear wheel bearings
2 x rear hub & abs rotor
2 x rear abs sensor
Hub nut off,didnt need a puller to take hub off,bearing was a bit fiddly,abs ring & they the 4 bolts
I didnt replace anything just used lock tite on 4 bolts
OK got the LCR rear splash shields on, need to source 2 new wheel bearing assembly's tomorrow to finish the job off. Bit of a bugger but cars on 156K and i suspect there the original bearings so cant hurt to replace them seeing as iam in that area anyway then.
FR vs LCR splash shields
Got a pair of wheel bearings kits for £100.
old vs new bearings
Bearing fitted and torque to 175Nm
EBC LCR ultimax disc fitted
just gotta switch the calipers and pads over now
