dazjstuart wrote
Do most cars not reccomend that they run on 98 though? Just the usual kind of arse covering from manufacturers, same with oils, you know the usual we reccomend this stuff.
No.
From the Leon manual, Section 3 Tips and Maintenance; Filling the Tank:
"General notes
• Unleaded petrol must comply with DIN EN 228 and leaded petrol with DIN 51 600.
• If, in an emergency, the octane rating of the available petrol is lower than that required by the engine, only drive with medium engine speeds and low engine loading. High engine loading with full throttle or high revs can cause engine damage. Fill tank with petrol of the correct octane rating as soon as possible.
• Fuel with a higher octane rating than that required by the engine can be used without limitation. There are, however, no advantages regarding output and consumption."
- and in the sections for most petrol engines:
Fuel 95 ROZ Super unleaded
- but in the section for the 1.6, 16valve petrol engine, the V5, LC and LCR
Fuel 98 ROZ Super unleaded
Correct me if Im wrong but if you start using 98 does it not take the ECU a wee while to adjust to the different fuel meaning you dont see the benefits straight away?
No, the ECU is retarding the timing based on the input from the knock sensors. You're constantly running on the verge of knock.
