kinners_mk1
Hi guys im after some expert advice, what mods should i be looking at to get the most out my seat leon cupra??
current mods are as follows:
 Revo Tech Re-map
 3” down pipe
 3” de-cat with oval exit
 Boost gauge
 Forge 007p recirculative dump valve
 Green cotton panel filter
 Lowered on springs
- im already on to the N249 and N112 bypass mod and the SAI removal (job for the weekend)
what should I be looking at doing next?
Assuming Stage 1 Revo, I'd look at:
Open cone filter - Jetex are good
Silicone TIP (turbo intake pipe) - B5 or SFS
Front mount intercooler (FMIC)
.....then go stage 2 Revo :)
What are you aiming for? No point giving advice of you only want to spend £xxxx and of you only want to go so far?
Thanks guys, straight on it!!
Just where i should go next to increase performance and if there is anything i need to be aware of i.e. engine faults or small mods which make a big difference!!
No limit really with cash, ill stop when im out of pocket, then start again when im in the plus :D
Clean the MAF and install cold running spark plugs :)
where can i get 'cold running spark plugs' and how much are they??
is there a specific advantage with cold running spark plugs?
