What year is your car?
Pretty sure this only affects cars upto 57 reg.
There are some fixes available for a few hundred pound but the official Seat repair is around £700 from memory.
Requires repair kit for ABS block, used to be able to get G201 and G202 as seperate sensors on older stuff but now its all built in to the ABS pump unit.
Working at a TPS site I sell loads of these, there is a repair kit available from us or dealers it costs £132 plus the vat plus fitting!! dont let them charge you more than that!!
I have heard that some dealers want to charge the full wack which is over £1000
Hi, sorry about jumping on to this thread but my ESP light came on and stayed on yesterday (Monday) morning. I've got a mate's code reader, which I'll use tonight.
Allbutt55, is the part you're talking about an OEM replacement, or the improved Externally Fitted Brake Pressure Sender? As described here...
Hi mate, its a repair kit that vag brought out when they started seeing problems with the abs pumps, you used to have to buy a complete unit but don't anymore. It will be a modified version though and i have never seen a replacement fail.
Takes a couple of hours, gotta swap the bits out then bleed brakes and abs pump, i can do it for you if you like but i wont be able to do it for around a month as im very busy atm work wise. Hopefully have moved into a unit by then too.
I also am having the same problems with my car. Has anyone used sinspeed or they replacing the faulty units? I dont know what to do, all advice appreciated.
