tufty you are a bufty tart!![]()
As always - cracking attention to detail
thats too Good.
Now to the most important thing, whats it going too add to the install power wise.
I notice in the above logs your map is requesting an AFR of 0.84..... mine is 0.81 what do you generally regard as the best compromise of requested AFR.
Lovely looking manifold / engine bay... Well everything, as m0rk says excellent attention to detail.![]()
That looks better than new tuffty a real work of art...I'm sure the effort will be worth while not just in cosmetic upgrade but power too. Nice welding Bill very neat. Is there nothing that can't be made at Badger 5. Well done both.
Your RR power upgrade is excellent especially considering such low boost. Its going to be worth its weight in gold at normal boost levels. I would like one of these in my life, are they economically viable for Badger5 to produce compared to the new kids on the block (IE and 034).
Your Tip looks great and coupled with your maff will bring the goods for sure. The question is not case of if it can make a reliable 400bhp i thnk its more a case of how much over.
But... Naughty boy wheres the meth install.![]()
