Pcv valve
Aug 27, 2012
581
Maidstone, Kent
Take a look at this, you can get silicone replacement that replaces the white one on the right and the T piece
The replacement
http://www.creationsmotorsport.com/product-detail.php?pid=15
Sep 4, 2012
719
Rainham essex
In the pic above it shows the pcv facing the front of the car. On mine it's to the left of the t piece right next to the pipe with a 90 degree bend . So my pcv is before the t piece facing the passenger side of the car. So in the pic above where the pcv valve is its just straight pipe.
nd-photo.nl
4,478
535
The Netherlands
youtube.com
I've replaced the upper and the one below the upper pipe (the wiggly one) and it was quite annoying to replace due to the lack of working space. Also the one-use clips are a bitch to unclamp. Havent replaced the one facing the front.
Feb 22, 2006
516
Penzance Cornwall
I have none of that crappy pipe work left. I removed it all and put in a catch tank which now vents to atmosphere. Benefit is no more oily crap going back through the intake. No more boost/vacuum leaks because the Pcv system that's left is totally separate. But be aware if you don't use a catch tank with 19mm inlets to match your current pipes from the rocker cover and oil filter housing you risk doing some damage as the pressure builds up, I tried and fired the dipstick out along with a load of oil.
Sep 4, 2012
719
Rainham essex
Don't you get an oily smell in the car though. How hard is it to fit a catch tank.
