TPMS Reset
Cliffie
Sorry guys, I have searched and still not found the answer.
I don't have the handbook so am a little lost.
Fitted new tyres at the weekend and the TPMS light has come on. Pressures are OK and I want to reset the light but have no idea where to start, please help.
Jan 31, 2012
703
Sheffield
You need your ignition on car not running press and hold the button and wait for the beep
Look near gear stick has the same symbol on button
DerbyForget
327
Burton on Trent, Staffs
centre console next to the handbrake... you know where the 12v socket is? there is a little button with a picture of a tyre and and explanation mark i believe. havent used it for a while cant quite remmeber. but hold it down for a few seconds say around 5 or so and it will reset the values and turn off your annoying dash light
EDIT : it works with your car running too
Deleted member 74601
Obviously, make sure your tyres are at the correct pressure. Tyre changing places just bang about 33psi in because they think it's about right, in this car, it isn't.
Petrol station is always my first stop after a tyre place
Cliffie
So what is the suggested pressures, I stick at about 29psi
a good tyre place/ garage will ask you what pressures you want in them. i have 32psi at the front and 30 at the back but if i have a full car knock the rears up to 36psi :)
I believe recommended tyre pressures for a light car is 36 front, 39 rear
For a full car I think it's 39 front 41 rear. That's just going from memory though. That's in my diesel, so may be a bit lower in a petrol.
DerbyForget
327
recommended tyre pressures differ from vehicle to vehicle and is dependent on the tyre, wheel size, load etc. ive always had 32 on the front and 30 on the rear and never had any problems with regards to fuel economy or tyre wear. not sure what you mean by the term 'light car' as this is not a recognized catergory - unless you are refering to a private or light goods vehicle?
EDIT :- Here are the recommended tyre pressures for my car, or any other mkII Leon FR TDI for that matter :-
Tyre Pressure results for the following Car:
Make: SEAT
Model: LEON
Spec: 5 DOOR HATCHBACK - 6 SPEED MANUAL - DIESEL
Trim: TDI FR
Engine: 1968
Introduced: 06 MAY
We have found 1 tyre size that matches this vehicle.
Tyre Pressures, for this vehicle, are as follows:
Front Tyres
2.2 BAR / 32 PSI
Rear Tyres
2.0 BAR/ 29PSI
so it would seem im 1 psi too high on the rear, i wont lose sleep over this :)
Cougar
356
Always been 32/29 - as it says on the filler cap! :p
Though it was 36/29 in the Boc! :O
Make: SEAT
Model: LEON
Trim: TDI FR
Engine: 1968
Introduced: 06 MAY
Front Tyres
2.2 BAR / 32 PSI
Rear Tyres
2.0 BAR/ 29PSI
I know they differ from vehicle to vehicle, when I said light car, I meant when you're driving with hardly anything in it, i.e yourself and a passenger. When I said heavy car, I meant, for example, with a full boot, or 5 passengers (although lets face it, no one is going to change it for the sake of a journey. I have my boot full all the time so they stay on higher recommended pressures).
It's also not true for ANY other MkII TDI FR, as you have the Pre-FL (according to your sig) you will have a PD engine, they might be different for those with a CR engine :)
As I said, best to always check the fuel filler cap :). I actually run my PSI's slightly higher than the recommended for economy anyway (only about 2/3 PSI)
