to my surprise i actually like that alot.
i bet it has stopped the rattles too if it had any.
the front plate makes your car look like it has goofy teeth in a wide mouth though lol.
Yer I know bout the plate but cheapest way to get a shortened plate lol
There no rattles either lol
Not been on here long so first time I have seen this thread. Stunning looking car mate, need to stop filling my head with ideas though haha
Love it mate, looks great, bet your well chuffed with it, matches the white exterior really well, top marks to whos done it ;)
whats next then?
Think it's some stance work to get it perfect that may include air
Epic!!!! That is all
Cheers bud
Looks so good!!How did you find removing your head lining and pillar covers ??
The rear pillers u have to remove the parcel shelf holders the there is a bolt behind the air bag sign and a couple under we're the parcel shelf holder was
Then the middle piller you have to Unclip the door sill and lower door piller so you can undo the 2 Phillips screws that hold it in place and slide the piller down to remove it also have to undo the 8mm multi spline bolt of the seat belt
And the front piller is just clipped in but it is quite a hard tug it needs to get it uncliped the just wriggle it out
Unclip the light cluster there 2 bolts behind the light cluster thing and 2 screws in each grab handle and remove the handle then undo the 3 screws the hold the sun visor the the roof and headlining then unclip the the clips at the back of the headlining and pull the rear rubber seal
Cheers bud
Cheers mate!
You have to remove all the cushions and seat cover to undo the bolt that are inside the seat
something like that
