Nick @ AmD's mk3 Ibiza cupra, pics pics and more pics
BIG4244
51
Dartford kent
Right well its a Ibiza mk3 cupra :) ill do a list of model currently then follow on with future and half complet mods :)
Engine mods.
SFS turbo intake pipe
K&N cone filter and 100mm cold air feed
CR turbos ko3s hybrid turbo
Airtec souble pass FMIC and custom brackets/pipe work
S3/LCR MAF housing and injectors and in tank fuel pump
Early non VVT Audi S3 revo stage 2
Milltek decat/down pipe
Blue flame non res centre section
"nick silver" AmD back box with oval tailpipe
Bolt down coil packs
N249 and secondary air bypass
10/50w Fuchs oil
aprox 290bhp and 310 ft/lb depending on day and lottery etc
Chassis mods.
AP coil overs with custom 70nm front main springs and 50nm rear springs
Front roll centre correction via ball joint spacers and track rod flip
Rear 25mm roll bar with custom rod end drop links
Power flex rear axle bushes
Front wishbone bushes power flex and rears vibratechnics solid bushes
Wheel stud conversion using custom radiused 80mm studs and tapered open ended nuts
15mm rear eibach spacers and 11mm (15mm machined) front eibach spacers
15x7 et35 black team dynamics wheels
195/50/15 marangoni zeta linea sport semi slick tires
Rear stub axles shimmed to increase camber and reduce rear toe in
Brakes.
Porsche boxster S front calipers slightly machined to fit under 15's
1144 minted pads and kinetix drilled and grooved 305mm discs
Rear disc and standard minted rads
Custom HEL brake lines (Ibiza cupra 1"longer and with porsche boxster end)
Some pics
Ball joint/track rod assembly And wishbone set up
Rear roll bar and drop link set up
Nick silver back box :)
My baffled sump :) Facebook me if you want one :)
Front brakes
Sexual brake lines
Studs (before spacers)
And comparison to bolts
Comparison between parada and zeta linea sport
A few on track pics
LOL
GF's first time on track
BIG4244
51
Dartford kent
Sooo little update... It finally went bang! Last dyno run was 309bhp and 309ft/lb :-( a little upset as I was without a car for 2 weeks but hey homonwards and upwards! So brief rundown of new bits :) ...
AGU block, 1mm oversized and block decked
All new bearings/gaskets etc
PEC 20mm wrist rods
Wossner 8.5-1 1mm oversize pistons
Ko4 turbo
Relentless v3 mani
Custom AmD 3" down pipe& decat
3"SFS ko4 tip
Bosch 044 pump
AEM watermeth
Some pics of bits and bobs
First off...the damage :-(
The poorly piston
Engine out and ready for inspection...which revealed it was past boring, new block then sourced
Engine bay degreased and pressure washed clean :)
Cylinder head, test fitting the v3 and cleaning/re lapping valves, also replaced cam chain tensioner guides
Heat foiling brake and clutch lines and mater cylinder, also the steering knuckle boot and A/C pipe
New goodies :)
All in
Starting to look like an engine...
3" in and 3" out
3" down pipe near completion
All back in...
Picked this up ready for when she's run in
BIG4244
51
Dartford kent
Did Kenny try and eat this for lunch ? :D You made a right mess of that mate :D
Lol I thought if be clever and see how much more power I could get 309 fr
A ko3s hybrid :)...but in winding the actuator up as far as I did it couldn't stop creating boost when I was flat out...resulting in a slight misfire over 20psi then the next day it blew up
